1. Trigger wheel with holes
2. Trigger wheel with slots
Both are the same price, $40 + $6 shipping.
These can be used to control an electronic ignition such as EDIS and Megasquirt units. Soon, I will have a bracket for a VR sensor, a bracket for the manifold air temp (MAT) sensor, and a bracket for the IGN-4 coil purchased from diyautotune.com.
http://www.diyautotune.com/catalog/ign4 ... p-409.html
The bracket for the MAT sensor will allow the the sensor to be mounted inside one air cleaner of a dual throttle body set up to get the most accurate air temp measurement.
The bracket for the coil will allow it to be mounted to the top of the engine case using the top 3 front most bolts that seals the case. Sorry, but I don't have any pictures of this yet.
Once i get all the brackets made and tested, I will make a set that will include the following:
1. Trigger Wheel
2. VR Sensor Bracket
3. Coil Bracket
4. MAT Bracket
The VR Sensor Bracket is shown below in aluminum, but the actual one is made of steel. I use aluminum for prototyping. I will attach the model numbers of the VR sensor that can be used with this bracket.
