Syncro Transaxle
- Pablo2
Syncro Transaxle
Since this forum is slow, here's a link to a Syncro trans thread:
http://www.thesamba.com/vw/forum/viewto ... le+service
aka Pablo, gears, Geary
9.36 @ 146 in '86
9.36 @ 146 in '86
- fusername
Re: Syncro Transaxle
wow. further proof that when I open a trans to rebuild, I will have 0 idea what wear looks like. Ugh i hate not knowing. good stuff, bookmarked.
- Henryhoehandle
Why didn't you loctite the pinion bearing nut? BTW your camera rocks!
- Pablo2
The harder Chromoly can present seizure issues that the soft OE nut never had. This is because the pinion bearing and aftermarket nut are close in Rockwell hardness.
I wished to convey my hesitancy to use Loctite (which can increase risk of thread seizure), while promoting an alternative (race-tested) method of securing the Chromoly lock ring.
The bonus is that this method allows using lubricating oil on the threads, rather than Loctite.
I also wished to point out the superiority of the Type II nut over the Type I nut .. a no-brainer in all Waterboxers.
9.36 @ 146 in '86
9.36 @ 146 in '86
- Henryhoehandle
Makes sense... I haven't had trouble with loctite seizing on the threads, but it does make it a pain to get the nut off if the bearing starts spinning in the case. A stock T2 nut will hold a lot and I have seen very few actually pull the threads from pinion force.
- Pablo2
It's normally off-road shockloading that causes the stock nut to expand and jump one thread. It doesn't take long to loosen further, allowing the pinion bearing to slop forward/rearward in its bore.
The stock nut in a Type II is the same as in a Type I .. thin and inadequate for some applications. The Chromoly version Type II is much thicker as it incorporates the washer .. and it has one or two more threads.
9.36 @ 146 in '86
9.36 @ 146 in '86
- Henryhoehandle
The chromoly one with the washer is the one I use for hp use.
That's why I never use loctite on the nut.Henryhoehandle wrote:.... it does make it a pain to get the nut off if the bearing starts spinning in the case.
I find many cores I pull apart have a loose nut. But that same loose nut was staked by the factory. My conclusion is that the width of the bearing support part of the case got pounded over time.
- Pablo2
Here's the latest installment on Syncro transaxle upgrades, from sister forum:
http://www.thesamba.com/vw/forum/viewtopic.php?t=568039
9.36 @ 146 in '86
9.36 @ 146 in '86
- Pablo2
I thought I'd update this thread, showing the parts we're now offering to build the ultimate-strength Syncro 4WD Vanagon transaxle ..
Gears with F1 tooth profiles (German steel, ultra-deep heat treatment):
![Image](https://www.thesamba.com/vw/gallery/pix/1623029.jpg)
Gun-drilled mainshafts supply oiling to all needle bearings (note replaceable 2nd gear synchro teeth):
![Image](https://www.thesamba.com/vw/gallery/pix/1707446.jpg)
Besides greatly increased strength & longevity, this new carrier offers integral splash plates/dams and a secondary thrust bearing for the pinion:
![Image](https://www.thesamba.com/vw/gallery/pix/1767276.jpg)
9.36 @ 146 in '86
9.36 @ 146 in '86
