CHT sensors
CHT sensors
I like the idea of the washer type you put under #3 but I'm trying to not spend a fortune on one. Has anyone tried the cheap Chinese ones on ebay? I know you get what you pay for but how much could they screw up really?
- Max Welton
Re: CHT sensors
The worst would be that it gives you incorrect readings which lead you to make a bad decisions. It could cost you your heads.
Max
Max
Re: CHT sensors
I spent major effort chasing home made CHTs with high readings. I finally bought quality factory crimped units and no problems since. GIGO. garbage in garbage out.
Mario dub shop sells the sensor connection probes for a fine price and he ships in 1 day.
Steve
My Baja Build
My Baja Build
- Max Welton
Re: CHT sensors
High as in inconsistent? or consistently high? Consistently high can be accounted for especially in my case.Steve Arndt wrote:I spent major effort chasing home made CHTs with high readings. I finally bought quality factory crimped units and no problems since. GIGO. garbage in garbage out.
Yea I knew about mario's shop. He owes me a cam sensor... lol. I've looked through mario's shop and I can't find where he sells just the sensor. I'm sure if I emailed him I might be able to get him to part with one but the sensor connection has them for a touch cheaper.
- woodsbuggy1
Re: CHT sensors
I highly doubt that the sensor connection has the Awesome customer support that Mario does!
Usually when I buy something based strictly on price I get exactly what I paid for(cheap=cheap).
Good Luck
Kenric
Good Luck
Kenric
Re: CHT sensors
http://thedubshop.goodsie.com/modified- ... emp-sensor
Go with quality first. Don't pay more for something cheap, only to find out you should have bought the better choice.
