I'm test fitting the tin etc on my rebuilt engine for my -73 fastback (also up for a rebuilt after 25 yrs rest in the garage) Man is this a puzzle
I'm about to fit the fan, but I can't remember how it was attached. I have the fan, fan/pulley, shims and the bolt with the wavy washer, but there must be more to it? Anyone? I've search all over the net, but can't find any pictures or exploded view.
As for the engine, balanced crank/flyweheel/kep2 pressure plate, 1641cc, CB2239, Lobe a lob sums up the internal in a std dual relif case. Hoping its going to be a nice cruiser.
I've attached a few pix of the fan etc, also the full flow set up, done the easy, but minf you tricky way. Don't know how many times I test fitted the shroud for clearance to the AN fittings.
Thanks,
Danny
