Kitchen Sink Strainer Oil Screen
risk
Post by risk »
Built an oil pickup screen out of a kitchen sink strainer!
I have an old APRM case, so my oil pickup is a little different than stock. Sump is Scat 1.5 qt.
Started with a cheap stainless steel sink strainer.
Flattened out the edges, drilled some holes and cut out for my oil pickup.
Fits great, I just hope it doesn't leak! I used a thick gasket on each side, and a thin coat of sealant on both sides of the gaskets.
Re: Kitchen Sink Strainer Oil Screen
Nice!
4agedub
Post by 4agedub »
Very nice indeed!!! Talk about thinking out the box.
VW Beetle 1303 EJ20T Subarugears Circuit Racer
VW Beetle 2332cc 200hp N/A Circuit Racer
VW Beetle 1969 2666cc Turbo Road Toy
The Newf
Post by The Newf »
...and you can use Drano if it gets plugged!
risk
Post by risk »
The Newf wrote:...and you can use Drano if it gets plugged!
Haha nice! lets hope not!
Here is a link to the strainer:
http://www.walmart.com/ip/38078360?wmls ... 55&veh=sem
There are lots of different ones out there, I just got lucky on the size and mesh etc.
FJCamper
Post by FJCamper »
Hi Risk!
Love it. Turn those screens upside down and they make great velocity stack screens. We use them on our Kads and the smaller ones fit Weber stacks.
The Newf
Post by The Newf »
Just funning ya bro.It looks 100 times better than the cheap Chinese crap that's spread all over the VW universe.Keep up the good work.
helowrench
Post by helowrench »
FJCamper wrote:Image
Hi Risk!
FJ,
Have you tried running those hump up vs hump down, to see if the interaction with the fuel standoff changed anything?
Bruce2
Post by Bruce2 »
Why wouldn't the stock screen work?
risk
Post by risk »
Bruce2 wrote:Why wouldn't the stock screen work?
The ARPM case has the pickup cast into it.. So I tapped the pickup hole for pipe threads and used a pipe nipple for my sump extension. The stock screen would not fit the larger diameter pickup tube.
Tapping it then inserting a fitting would reduce the flow area by about half of the original, right?
risk
Post by risk »
Steve Arndt wrote: Tapping it then inserting a fitting would reduce the flow area by about half of the original, right?
Nope.. i did my homework beforehand. I had to drill the pickup larger for the 1/2" pipe tap. The id of the pipe nipple is around .635" and the id of the inlet hole in the case at the pump is around .625" or 5/8.
How did you figure it reduced by half?
I figured the ID of the fitting that would screw into the tube would be reduced compared to the tube original ID (obvious). Hence reducing diameter some, and area a bunch. Carry on, just making sure you had this worked out. Not knocking your work.
I wish I had an ARPM case. I have the matching ARPM 2 stage OG pump :)
risk
Post by risk »
Steve Arndt wrote:I figured the ID of the fitting that would screw into the tube would be reduced compared to the tube original ID (obvious). Hence reducing diameter some, and area a bunch. Carry on, just making sure you had this worked out. Not knocking your work.
Hacking on an original ARPM case really made my stomach drop.. but it was either that or weld an extension on.
mike1211
Post by mike1211 »
risk wrote:Built an oil pickup screen out of a kitchen sink strainer!
Hello
Can you tell me that from where i can buy this kitchen sink strainer??
