My 1974 SlantNose Project
Type 4 Unleashed
Post by Type 4 Unleashed »
Finally have a place close I can work. Got the garage pretty much cleaned up finally after my last move. Got the car here Monday, Now I can walk out into the garage anytime and do wrenching.
Believe it or not it rained today, so over cast so the pics are a little dark. I don't know if you can see my garage floor, but had it epoxied with plastic chips thrown in before we moved in. Now, since I don't have a lot of room, I am going to have to and get a set of car dollies to move it around with ease when needed, cause to get it back against the wall as it is, I had to roll it forward & backward a few times to get close enough, so that's the last time I am doing it that way.
It's mostly re-assembly now, almost all the rubber is new from the Dealer, factory bumper tops and so on, including a brand new dealer dash top. I can now start unpacking all the pieces and see what I have. All the aluminum trim is new and was black powder coated. The aluminum trim that goes around the windshield is new and is black and came from the dealer that way still packaged with dealer stickers on them.
EMW
falcor
Re: My 1974 SlantNose Project
Post by falcor »
With some square tubing and steel caster wheels you could build yourself something like this:
http://matsgarage.com/wp-content/upload ... G_5127.jpg
Its worked great for me in my garage.
Type 4 Unleashed
When I get the chance I was going to see how much the material & the casters were going to cost. There are some pretty cheap dollies out there, but then you get what you pay for. I would prefer the hard rubber casters to the metal ones. I've got a hardware store that carries quality parts, so I will see which way I go. And thanks for the pic.
EMW
djway3474
Post by djway3474 »
I bought 4 of the small furniture dollies at Harbor Freight and move a Karmann Ghia around with them no problem. Around $8 each
Type 4 Unleashed
I splurged, a little better than furniture dollies but cost a lot more, but I am happy with them. Working on the car will be a lot easier now. I've been out to the storage picking up all the pieces that came with the car.
Some time ago, I had picked up a new motor for the car, and I mean a New motor, It's a brand new Factory built Super Vee motor, brand new factory case, cyl's, and heads. But the issue it's only a 1600cc Type lV motor with 87.5mm pistons & 1.7 heads, to run in the 1600cc Super Vee class, and so I was thinking of throwing on a set 96mm pistons and a set of 2.0 ltr heads for a little more power and torque from a 1911cc motor. But then again it might be a waste for the motor, especially if there's some one looking for a Super Vee motor. So a stroker motor may very well end up in the car instead.
EMW
What are you planning for front turn signals?
Are those glass or modded stock front fenders?
Looks nice!
Type 4 Unleashed
Piledriver wrote:What are you planning for front turn signals?
Looks nice!
I was thinking something in the fog light frames since I don't want to cut holes into the bumper, I have some broken ones to play with, but also thinking about new ones out of aluminum to better support the turn signals.
No, the fenders are all metal.
New Factory Dash Pad
New Factory Windshield Rubber, and New Factory Windshield Trim, which I didn't know the aluminum pieces came in black.
EMW
Those are some brutally expensive bits...
The LEs had blacked out trim, at least mine did.
Type 4 Unleashed
Here's a pic of the Super Vee motor that I was thinking of putting in this car. As much as I would like to find out what cam this has, I can't take it apart to find out, other than putting on some 96mm p/c's and 2.0 Ltr Heads. But I still find it interesting that a MAX 6,800 RPM was stamped on the block ?
EMW
