webcam 251 or Fk-89
CarenzoCustoms
webcam 251 or Fk-89
Post by CarenzoCustoms »
Hi folks, I´m from Argentina
I have a 2332cc normaly aspirated, only drag racing use, type 1 engine with these specs,
84mm cb crankshaft
5.7" cb rods
94mm forged pistons
Competition eliminator 48x 40
48mm EFi bodies
Progresive merged exhaust
13,4 CR runing 100% methanol
hve beenn using webcam 251 with very good result
267hp and and max 8200 RPM
I have overrev and cut a valve, broke 1 piston, cylinder, etc.
Now i´m going to rebuild the engine, and i´m was thinking the possibility to change webcam 251 for a engle FK-89
What do you think
This is a video of my car if you like to see
Thanks in advance
Pedro
Island bugs
Re: webcam 251 or Fk-89
Post by Island bugs »
I had very good luck with the Webcam 251. It measured more lift than the Engle on my engine. Had almost the same power as previously with a roller cam setup. I would use it again.Wayne
