I need super squish piston ring set. any one know what size is it?
thanks
Sper squish piston rings
Re: Sper squish piston rings
They are made by Wiseco, and designed by Endyn, but the only way to be sure is ask John at aircooled.net.
- ps2375
There must be something left to measure..
- Chip Birks
I just use Grant rings with mine. Never been a problem finding them, just measure, or ask John.
Aircooled.net.
I run total seal second rings on mine and the standard other rings. I have my original stock Wiseco second rings if you could use them. Probably want a whole fresh set though and not do a partial if you are bothering. Been running mine since 2005.
Steve
My Baja Build
My Baja Build
- Stripped66
I'm running Total Seal standard top and 2nd rings, and Deves oil rings. For some reason, the ring land was not deep enough for the TS oil ring, so I reused the Deves oil rings that I had...I don't know if it was my pistons or a bad batch of rings from TS. YMMV
