stock rod length and pin height type 4 2.0
- Paul H
Anyone know what the rod length and pin height is on a stock type 4 2.0 motor ? A friend is fitting a 78.4mm DPR crank so we need to figure out what the best T1 rod and piston combo is
Re: stock rod length and pin height type 4 2.0
Rod length: 131mm, pin height 36mm.
!31mm rod length , stock 2 lt pin height is 36mm .
- Paul H
Wow an instaneous response
So using readily available 137mm type 1 rod and a 35mm pin height Type 1 94mm piston we need spacers of about 10mm which
will cause pushrod tube troubles
AA pistons have a forged 96mm kit with a 30.08mm pin height . also Porsche length rods 135mm . heaps of options using Type 1 rods . I've just finished a 103 X 78 using 30.08 pin height and 135mm rods . no clearance issues and still using the standard pushrod tubes .
- Paul H
I'll have a look at those but I try to avoid 2618 race type slipper skirt pistons. The Keith Black hypereutectics seem to have disappeared
- Type 4 Unleashed
Hi Paul
The source for Keith Black Hypereutectic pistons is EMW.
EMW
EMW
