Crank shaft size?
craigvwdude
Crank shaft size?
Post by craigvwdude »
Fellas,
trying to figure out what size crank I have. Does anyone know of the main and rod bearing journal size of a 1.7/1.8 crankshaft? Also the case size for the bearings?
I've misplaced my type 2 repair manual so i can't search there.
Thanks for any help!
Craig
sideshow
Re: Crank shaft size?
Post by sideshow »
The quick check is 50mm/55mm on the crankshaft rod, smaller is the 71mm stroke. Mains don't change and follow the wassers at 60mm.
