Deutz Sleeves
DaveDorson
Deutz Sleeves
Post by DaveDorson »
I've found some reference to these being used. I was bench racing with a friend earlier and we were talking about short stroke big bore engines.
I mentioned that a friend is rebuilding a Deutz FL912 aircooled engine at the moment, and he's got some sleeves sitting around.
My understanding is that they need to be trimmed to length to fit, and bored to 101.6 (4") but I can't find any further details about these modifciations. Is it just a case of cutting the case end down, or does the cylinder head side need some trimming and turning also?
What piston's are folks using?, there'a reference on a South African forum to people using iron duke pistons, but I assume these are HUGELY heavy sort of negating the benefit of the 66mm crank.
Type 4 Unleashed
Re: Deutz Sleeves
Post by Type 4 Unleashed »
Here's a link to that exact same subject with plenty of info: Deutz 912 Cylinders
EMW
DaveDorson
Re: Deutz Sleeves
Type 4 Unleashed wrote: Thu Sep 27, 2018 10:50 am Here's a link to that exact same subject with plenty of info: Deutz 912 Cylinders
Cheers.
I'd read through that, but I can't see clear answers as to where you need to remove material from.
I'm assuming it's all from the end that the case sits in.
Also doesn't really answer my questions about pistons.
Unless of course I missed that.
I'm happy to have a go and figure it out, but I'd really need a spare engine to do so, as it's not like you can un-cut heads and a case.
Arnoud
Re: Deutz Sleeves
Post by Arnoud »
If youre on FaceBook search for GetBackonTrack:Jacob has quite a few pictures on his gallery.
wreck
Re: Deutz Sleeves
Post by wreck »
the cylinders get shortened from the case end by a lot . I used a small chisel to break off the fins then a flapper disc on a grinder to smooth the surface to make it easier for the guy with the lather to shorten them and machine to the same specs as a type 4 barrel . Work out which crank/rods you want to use and then see what Small block V8 pistons you can find that are close in gudgeon pin height . Then get the cylinders bored to match the pistons and final machine to exactly to the right length to suit your required deck height .
DaveDorson
Re: Deutz Sleeves
Thanks all for the replies.
I've had a chat with a friend of mine with some massive old manual machine tools, it looks like I've got free access to what I need there, so now I just need to find some cylinders and suitable pistons.
I've got a junk (seized up from standing 1.7 motor that I think I can use as a cylinder head, crank and case donor. All being well this will form the basis of a 66x100+ motor.
Bit of a foray into the unknown this. Wish me luck.
