1835 Turbo redo!
Thorkhild
1835 Turbo redo!
Post by Thorkhild »
I'm rebuilding an AJ Simms "under the decklid" turbo kit. The plan is to change it from a carbed draw thru , to blow through injected, Fuel and Spark controlled by a Megasquirt II v3.0 with 32lb injectors.
This is what im starting with
P&Cs will AA 92mm Thickwalls. Ignition is a IGN-4 tower w/ a Dubshop Hidden Wheel.
Throttle is going to be half of this 45 IDA throttle body from Hong Kong (ebay special) : Image .
And all of this fitting in my 74 Standard .
V8Nate
Re: 1835 Turbo redo!
Post by V8Nate »
Bitchin:)
Sent from my SM-N950U using Tapatalk
Thorkhild
Post by Thorkhild »
Other things to fix is the location of the wastegate, its too close to the pulley. I'm also going to fab a new "up" pipe to place the turbo in a better location. The quick plan has me not going over 10 PSI and to keep intake temps down so I don't need a intercooler. I have been reading about meth/water injection. My new TB has the injector bung, so i'm going that route w/ a 5th injector.
Thorkhild
Post by Thorkhild »
Other upgrades are in the mix too:
rubenski
Post by rubenski »
Nice!
Verstuurd vanaf mijn SM-A750FN met Tapatalk
sideshow
Post by sideshow »
Wow, split shaft design I thought that fell of of favor in the Solex P11 days. Are you running it as a single and what is the linkage like?
Thorkhild
Post by Thorkhild »
I'm only going to run "half" of the IDA on a "T" intake. Once I get it in my hands, I hope I will be able to adapt the TPS switch and throttle lever from my IDF TB from CB performance.
rubenski
Post by rubenski »
Where did you get the fuel rail fittings?
Those are super expensive over here. 58€ each (180°)
Thorkhild
Post by Thorkhild »
GARRICK.CLARK1
Post by GARRICK.CLARK1 »
Hi. I see you have a CB fuel T on your fuel tank. You need some copper O rings in side the CB Tee piece as the there are to many threads on the Tee and it will leak fuel.
andy198712
Post by andy198712 »
GARRICK.CLARK1 wrote: Mon Dec 31, 2018 10:41 am Hi. I see you have a CB fuel T on your fuel tank. You need some copper O rings in side the CB Tee piece as the there are to many threads on the Tee and it will leak fuel.
i shortened mine so it didn't bottom on on the tank before tightening, its rubbish this happens but there you go
rubenski
Post by rubenski »
GARRICK.CLARK1 wrote:Hi. I see you have a CB fuel T on your fuel tank. You need some copper O rings in side the CB Tee piece as the there are to many threads on the Tee and it will leak fuel.
I installed mine a few days back,
I have yellow locktite on it, will it leak?
GARRICK.CLARK1
Test it. Sit tank level. put a pint of fuel in it and leave over night. I would remove the TEE and O ring it/shorten it , which ever is easiest for you.
rubenski
Post by rubenski »
It has an o ring in it.
I will wait till i get my other couplings and fuel lines before i fill it again.
I have to wiggle and turn to get the tank in. Verry uncomfortable.
GARRICK.CLARK1
Yes, mine came with an O ring ,but its too deep inside the Tee piece, That's why You need a couple of copper O rings in place of the RUBBER O ring. Don't risk fitting the tank. I didn't no mine was gunna leak till I fitted it to the bug and added fuel.
