bushoarder
Post
by bushoarder »
Evening
I have an 1800 (41x34) heads and have 40 idfs fitted. It’s a stock motor so I would assume that there are some standard jet profiles that work?
I have
28mm vents
120 mains
55 idles
F11
33 pump
Seems to guzzle fuel but better than 50 idles and 130 mains!
Bogs a bit now I’ve gone 55 idles so I assume 50s are needed. On the 55s the idle screws are many fewer turns out.
Anyone any thoughts? Will rolling road it eventually but there must be a closer ball park setting.
Also, annoyingly backfires on over run but only on long over runs from 3krpm. Exhaust leak or too rich?
All help appreciated
Ephry73
Post
by Ephry73 »
32 vents
bushoarder
Post
by bushoarder »
I ended up with the following after rolling road:
Mains 125
Idles 50
The rolling road didn’t look at vents etc. I had it too rich on 135 mains and spot on elsewhere. With 125s it’s running at 11-13 afr
Would you suggest 32 vents in a bus? 28s would give more torque wouldn’t they?
Ephry73
Post
by Ephry73 »
I suggested that based on the jetting you had. Stepping down the main was not a bad idea.
