I noticed that some of the aftermarket type 4 flywheels don't have the line up pin hole. Does it manner if its missing?
https://www2.cip1.com/shoppingcart.asp
https://type4store.com/200mm-conversion-flywheel.html
https://www.thesamba.com/vw/classifieds ... id=1827212
https://fatperformance-rimco.com/produc ... conversion
200MM TYPE 4 FLYWHEEL?
- VIPERGREEN76
76 SEDAN
EC type 4 Conversion project
Re: 200MM TYPE 4 FLYWHEEL?
The fat performance one has the pin hole. I imagine the pin hole is for when the crank and flywheel are balanced as a single unit.
Hi!
The flywheel i got(probably AA)has the pinhole.
Cheers,Arnoud
Cheers,Arnoud
- VIPERGREEN76
The flywheels with the pinhole cost more. I removed the pin from mine to save $ on the flywheel.
76 SEDAN
