So to that end, I've taken advantage of some of the Black Friday sales and ordered a few parts to get this project moving finally. I'm hoping that you seasoned T4 guys can look at the combo below and provide suggestions on anything I'm missing or off base with. This will be my first T4 build, but I've built a bunch of T1 engines (among other non-vw stuff), so not really an engine newbie.
Here is what I have for the 2056 combo so far:
-"stock" 2L bottom end: STD/STD 71mm crank (balanced), balanced stock rods, etc, etc REUSING
-AA 96mm hypereutectic pistons w/biral cylinders (24mm pins, 7cc valve pockets, for 2L stroke engines) PURCHASED
-relatively new (<3k miles) AMC 2L heads (39mm intakes, XXmm exhaust, ~55cc chambers) PLAN TO REUSE
-Web 86a cam, w/web solid lifters, and new cam gear PURCHASED
-Set of Web HD single springs (to be installed in my heads) PURCHASED
-034 SVDA distributor REUSING
-T4 style 200mm conversion flywheel, Kennedy STG 1 p/p HAVE
-DTM shroud w/T4 oil cooler HAVE
-Dual 40 IDF's w/CB linkage REUSING
-Ahnendorp T4 merged header HAVE
How does this combo look so far? What am I missing? A few thoughts/specific questions:
-What do I need to do valve train wise? I was really wanting to just reuse my current rockers (10mm std adjuster type). This is/will be a pretty mild motor, and all these parts I have are in great shape. I assume I should get a solid rocker kit for it to replace the stock springs/washers? I also just realized this morning that my current pushrods are hydraulic lifter specific, so I need to pick up a set of HD aluminum or chromoly pushrods as well. Do I need to change to the HD rocker shafts? With only single HD springs, I'm not expecting huge challenges here on the valve train.
-I realize my heads are going to be the limiting factor on this engine. My plan was just to clean them up, re-lap the valves, and run them as is (they are not very old and only have a few miles on them). How bad will they be performance wise? I also considered having them sent out for larger valves (who/where?), and considered picking up some different heads all together (AA has some AMC heads with 44x36 and 42x36 valve arrangments that are on a great sale through the weekend, ~20% off). I'm really trying to balance $$ vs HP to maximize my bang for buck. I don't expect this to be a screamer, I just wanted something a little more potent than the bone stock hydro lifter 2L.
-With the stock crank/rods and 96mm AA cylinders, where should I expect my deck height to roughly be? I'm not familiar with T4's in this regard. I know T1 jugs have varying lengths depending on bore. I was just trying to figure out what sort of deck I can expect to figure out what CR I might manage to get from the combo.
Any thoughts, comments, etc??? Any help is appreciated.
