Solid Spacer Rocker Alignment
Deefer66
Post by Deefer66 »
I've asked on my side of the pond thought I'd ask here too. Most posts on this discuss geometry, parallel at half lift etc, some overall side play at 0.004" is good. Can't find horizontal alignment comment anywhere?
Should you aim for middle of valve stem or just off centre to encourage valve rotation..as a starting point ?
Fyi stock 2lt crank, 73/86 cam TP's swivel feet adjusters in clearanced rockers...in a bus..well it will be soon
Sent from my SM-G930F using Tapatalk
Deefer66
Re: Solid Spacer Rocker Alignment
Post by Deefer66 »
Aiming about here mid lift at the moment..
Clonebug
Post by Clonebug »
How many turns out do you have the adjuster???? It seems to me on the second pic that your adjuster and valve stem are not lined up straight.
My understanding is that is supposed to happen at half lift.
I would make sure you have a least one full turn out on the adjuster to allow for valve adjustments that tighten up over time. 1.25-1.5 might not hurt.
To fix your issue my thinking is you need to confirm the adjuster setting and then probably lower the rocker shaft and adjust the pushrod length probably shorter to take up the slack.
Run it through the full lift and half lift swing again and see if it changes.
As far as your horizontal alignment.....It looks good to me.
I'm working on my geometry as I speak. My new 1.25 rockers are coming out at 1.34-1.38:1......... :roll: :cry: :x
I'm not an expert by any means though, so take my advice with a grain of salt.........
Deefer66
Post by Deefer66 »
Cheers, adjusters are a good couple of turns out I've countersunk the rocker to let them go in a bit.
They hit parallel at about 45% max lift at the moment so I'm going to let that go as it's a bus and they're swivel feet and I don't want to get into a world of pain of shortening push rods..
Clatter
Post by Clatter »
As to your 'sideways' question.. If i'm reading it right..
The solid spacers you sand down to set rocker end-play on the shafts..
You want to end up with the adjuster a 'bit off-center' so as to promote valve rotation.
When you set them up you'll see them coming out a little skewed to the side,
And that's good.
You don't want the foot of the adjuster hanging off the side of the valve tip (too much),
and you don't want it right in the center, either.
Super-precise, eh?
Long story short is they don't have to be super exact,
But you don't want any centered.
Deefer66
Post by Deefer66 »
Clatter wrote:As to your 'sideways' question.. If i'm reading it right..
And that's good.
Super-precise, eh?
Thanks.. ideal answer Image
Sent from my SM-T580 using Tapatalk
Deefer66
Post by Deefer66 »
Clonebug wrote:How many turns out do you have the adjuster???? It seems to me on the second pic that your adjuster and valve stem are not lined up straight.
Got em shimmed up..pretty straight at mid lift now tooImage
Clonebug
Post by Clonebug »
That looks better to me.....
Deefer66
Post by Deefer66 »
I even did it in imperial measurements just for you folk over the water!..and to compare to Webcams sheets
Is it normal for exhausts to be 95% of advertised.. all mine were down at 0.4"
Guess it's a rocker arm offset thing...?
Clatter
Post by Clatter »
Exhaust rockers always lift less.
Deefer66
Post by Deefer66 »
Clatter wrote:Exhaust rockers always lift less.
Less than they're supposed (advertised) to or just less than intake.
Clatter
Post by Clatter »
Both.
Deefer66
Post by Deefer66 »
Cheers bud
Type 4 Unleashed
Post by Type 4 Unleashed »
I am surprised nobody caught this... :evil:.. You want your adjusters centered, SWIVEL FEET ADJUSTERS WILL NOT ROTATE THE VALVES.
EMW
Deefer66
Post by Deefer66 »
I was just thiking that the other day when I was thinking about geometry and how these plant their foot then rotate on the ball not travel along top of valve.. but does the spring compression/ decompression cycle not cause rotation too?
