VW IRS transmission Help
alkonx3m
Post by alkonx3m »
Hello Everyone. I have an IRS transaxle that throws me the reverse. I don't know what can be damaged, somebody can help me? Also, I'm looking for a place that sells VW transaxle parts in US.
Thanks..!!!
Casting Timmy
Re: VW IRS transmission Help
Post by Casting Timmy »
Usually it's the sliding reverse gear, you need to know what style reverse gear and what tooth count reverse gear you need. The tooth count will be based on the 1-2 slider's teeth, which can also be damaged and causing it to pop out as well.
weddleindustries.com would probably be your easiest as they have the best website.
Folts Transmissions and Erco are two other places to buy parts from
