Here is my first attempt. Everything worked as designed ( I use that term loosely) but the screen was not in good line of sight. On top of that, I was unhappy with the accuracy of both the OEM speedometer and fuel gauge.
Fast forward to this weekend...
Overkill? No doubt. Why do this you may ask... Because Racecar!
The screen consist of a hacked tablet mounted to a pivot ball that's attached to dash via a plate that replaced the OEM speedo. The screen is attached to a Raspberry Pi 3 running TunerStudio, of which is connected to a Megasquirt 2 EFI. Vehicle speed is acquired with a GPS dongle. Jury is still out on its accuracy, I still need to verify. I use a wireless keyboard that I keep under the seat if I need to make any adjustments.
The center console was fabbed by yours truly. Consist of battery shut-off switch, fuel gauge, and light switches.
Best part is... this can all be reversed back to stock if the mood strikes as no cutting and minimal drilling has been done.
Enjoy!
-Nick-
