Greetings folks--
AFTER recently assembling a 1641, I made a trade to a friend for a EMPI deep sump, however, he could not find the pick up tube extension, so I must acquire one elsewhere.
CB Performance sells two different extended pick up tubes, but I UNDERSTOOD they need to be installed in a disassembled case. I may be wrong about this. Can someone please suggest a source for an extended pick up tube? Perhaps hardware as well?
Thanks in advance
H2OSB
Oil pick up tube
Re: Oil pick up tube
I used a piece of 3/4”steel tubing and brazed it on. It’s a little tight, but doable with the engine assembled.
