Dry sump case to wet sump
Druck1
Post by Druck1 »
I have a vintage Scat Killer case, dry sump. I want use it for a engine build but prefer wet sump. Any issue adding a Gene Berg or similar sump? Machining required, but any other issues to tackle?
Re: Dry sump case to wet sump
How are the oil pressure relief valves setup on the Scat? Some use external reliefs.
Druck1
Post by Druck1 »
I believe this is external pressure relief. I need to go outside the case for oil cooling as well
richie,uk
Post by richie,uk »
What oil pump are you going to use? I am pretty sure they don't have provision in that case for an oil pick up tube? and you need the matching scat wet sump
cheers Richie
Druck1
Post by Druck1 »
I plan to use a 26mm pump
I will use a Autocraft external pick up tube
Appreciate your help
