Head machining to increase compression
leonardthomas1556
Post by leonardthomas1556 »
5 Best Vacuum Tips And Tricks
We all want our house always to be clean, and that makes vacuums become our best friends. But we can do more than that with it! Utilizes these tips below to save your time and energy when using vacuum cleaners and make the vacuum work effectively.
  • Tip 1: choose the right vacuum first
Which type of vacuum do you want to choose? Upright or canister? Bag or bagless? Do you have pets? Each family has their own demand when choosing a vacuum cleaner and understanding your requirements will save you a lot of time cleaning. The upright model is perhaps the most preferred by households. If you have carpeted stairs or rugs, or even pet hair, this type of vacuum could be the safe choice. Upright vacuum cleaners are usually cheaper than canister one, but it is heavier and hard to push around.
If you choose an upright cleaner and have hardwoods, make sure to get one with a brush roll that can be turned on and off (on for carpets and off for hardwoods). One of the most recommended products is shark navigator lift-away deluxe NV360, which is available at a reasonable price of 174$. It is an upright vacuum but also has a unique detached canister mode to increase its portability.
  • Tip 2: Follow gravity rules and start from the top down
When cleaning, you should remember to follow the rules of gravity and cleaning from high to low position. When you dust off blinds, curtains, shelves or ceiling fan blades, all of the particles will eventually settle on your floors. Cleaning floors first will make you vacuum twice.
During deep clean, where I remove all the dirt from the shelves and clean the surface thoroughly, I like to use the Crevice tool from my Shark Navigator Lift-Away Deluxe NV360 Upright Vacuum; then the canister mode will come and help me with high surface areas.
  • Tip 3: Take advantage of your vacuum attachments
Your vacuum is not used just for the floors! You can always take advantage of the attachments to keep your curtains, upholstery, windows clean as well. I like the shark navigator nv360 because it has two modes, the first one is for hardwood or tile floors, while the second one is called spin mode that you can switch to, and this mode is really handy when it comes to carpets or upholstery.
  • Tip 4: Plan a schedule and stick to it
One of the keys to success is to be consistent with your plan, and it is true as well for cleaning. Keeping a regular cleaning schedule will not make your house always be clean, but it also improves your lifestyle and protects your family’s health.
Since owning a Shark NV360, cleaning house is not my problem anymore. With a wide and large cleaning path at 11”, I do not need to push the vacuum around many times, and that saves me a lot of time.
  • Tip 5: Let robotic sometimes do the work for you
Robotic vacuums can squeeze into tough positions like under the sofa, but they do not have the power like canister or upright, making them not ideal for stairs. However, if you are busy but still want to stick to the schedule, then a robotic vacuum could be a great choice.
Picked For You: Shark NV360 Reviews
Above are five tips that I usually use when cleaning a house with vacuums. After sharing these tricks, I hope to help you save your time and energy when cleaning your house.
Last edited by leonardthomas1556 on Wed Jul 05, 2023 12:51 am, edited 2 times in total.
John S.
Re: Head machining to increase compression
Post by John S. »
This is a sticky.
viewtopic.php?t=117946
