getting closer
dino1369
getting closer
Post by dino1369 »
My first turbo build is inching along.. Holley tapped for vacuum. End casting tapped for the CB black box. IAT and wideband bungs welded. Removable apron almost done. Just got most of the fittings for the fuel system. I'm going to try to run it without a regulator. The fuel pump puts out 7psi so I''m hoping the carb can take it. I'll need to make a bracket for the accellerator cable once I figure out which one I'm going with. Also hoping my stage 1 plate and racing daiken hold. We shall see. Enjoy the pics.
dino1369
Re: getting closer
Post by dino1369 »
Got the turbo blanket fitted. Getting there
dino1369
Re: getting closer
Post by dino1369 »
Pumping out the jams while I work
V8Nate
Re: getting closer
Post by V8Nate »
Bitchin! Nice work
dino1369
Re: getting closer
Post by dino1369 »
Thanks Nate. I have no idea what I'm doing. I just hope it doesn't blow up when I start it. Fingers crossed.
rubenski
Re: getting closer
Post by rubenski »
Nice, what kind of engine?
Verstuurd vanaf mijn SM-A528B met Tapatalk
madmike
Re: getting closer
Post by madmike »
It won't blow up starting it,, Just keep a sharp eye on the A/F ratio gauge!!!! when boosting :wink
I don't think that clutch disc will hold.,,, mind didn't :lol:
madmike
Re: getting closer
Post by madmike »
Hey Rube, I thinking it is one of 'AJ's' 2180cc :wink:
dino1369
Re: getting closer
Post by dino1369 »
It's not an AJ engine. The header isn't from him either. Neither is the carb. I've been collecting parts and cobbling this together over the last few years, and doing everything myself. Does this vac/boost line diagram look right?
madmike
Re: getting closer
Post by madmike »
Good u pieced it together,, don't care for his Business dealings ,,
Vac diagram, looks like it will work , mine looks like spaghetti cuz of the reflection on the shroud :lol:
dino1369
Re: getting closer
Post by dino1369 »
Almost there! On the home stretch. Just power to the gauges, throttle cable, check the fuel system for leaks and make sure the black box connects. Soooo close.
rubenski
Re: getting closer
Post by rubenski »
With a hat for when it rains?
Looks good!
madmike
Re: getting closer
Post by madmike »
looks good! 8)
dino1369
Re: getting closer
Post by dino1369 »
Having issues getting the laptop and the black box to connect. Windows wont let me change the driver. Eventually I'll figure it out... I hope.
dino1369
Re: getting closer
Post by dino1369 »
At least the wiring is done.
