bus sometimes won't start
ls
bus sometimes won\'t start
Post by ls »
Hi. I have a 79 bus, automatic. One day it wouldn't start, didn't make any noise at all. I wanted to check out the ignition switch so I dropped the steering column and was going to take off the steering wheel when I happened to try it again, it started. I seems to have to do with whatever I did when I dropped the steering column; jiggled the wires, possibly. Now it randomly starts or doesn't start. I want to check for shorts, or loose connections, possibly to the starter or battery (?) but I'm not sure what to look for. Thanks.
stagger lee
Post by stagger lee »
probably worn connections on the ignition switch, you can replace the switch at the back of the ignition barrel, and for good measure fit a relay to power the solenoid directlly from the battery, the relay is controlled from the original solenoid wire coming from the ignition switch, better descriptions/instructions can be obtained from www.type2.com
