Does anyone know how many splines are on the outer and inner ends of a Van rear torsion bar? I know that the Beetle torsion bars have 40 inner and 44 outer.
Mike Ghia
Modification is a form of Art.
Rear Torsion bar splines?
mike,
if you can wait for about six hours, i can look it up.
scott lyons
scott lyons
No probs.
Any info is great.
MG
Any info is great.
MG
- Hank Winning
The early transporters had 44 splines on both ends
hank
hank
michael,
sorry for the long delay.
hank above is partially correct, but his numbers probably refer to swing-axel rear ends.
my bentley says 44 splines inner and 48 splines outer for a spline angle of 8deg 10min inner and 7deg 30min outer.
hope that is of use.
scott lyons
scott lyons
- Hank Winning
swing axle transaxle had 44 on both ends
Thats great.
Thanks all
Can anyone verify if the early van splines are for the ealry bay ('68-'70) or split van?
Mike Ghia
Thanks all
Mike Ghia
Ok... but what about the early bays which are IRS but have the larger 205mm PCD drums/wheels?
MG
MG
mike,
the numbers i posted should apply from 68 to 79. (from bentley)
scott lyons
scott lyons
