<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by UncleBob:
By the way, what is special about Bosch Distributor Grease? <HR></BLOCKQUOTE>
I too have been using the Bosch Distributor Grease for many years and not only on distributor shafts.
I also apply the Bosch dizzy grease on the clutch cable when I feed thru the clutch tube as well as the accelerator cable, lube the input shaft and gland nut bearing prior to installing the engine, grease the door/decklid/trunk latch assemblies, shift rod and bushings as well as the ball on the shifter that sits in the shift rod, and many other uses.
Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
CA license plate: BNZAI KG (Banzai Karmann Ghia)
1996 Jetta GL
Wolfsburg Pacific VW Club (East Bay, CA):
http://www.wolfpacvw.itgo.com
V.V.W.C.A. - Golden Gate Chapter:
http://www.ggcvvwca.org/
Road Relics VW Club (SF Bay Area, CA):
www.road-relics.com/
Gene Berg Memorial Cruise:
http://www.gbcruise.org
