Seat tracks for 68-74 Ghia
- JC-ATL
I need the driver's side outer seat track for a '68-'74 Ghia. I'll take a full set from that side, if I must.
Help.
Help.
I will gladly take them off your hands........
I just replaced my pans in my 1970 cab. and the rails took a little beating. My address is:
Ed Stokes
2403 E. 2nd St.
Tucson, AZ 85719
Let me know what kind of payment will help this along.
Ed S
estokes@zygo.com
Ed Stokes
2403 E. 2nd St.
Tucson, AZ 85719
Ed S
estokes@zygo.com
- Phil Smith
Not to be a Smart @$$ but with a little bit of work with a chisel or even a screw driver the tarboards come off, and if the metals half rusted a grinder with thin cutting blade with go right through it, I've done this a few times and when your friends with a guy who owns over 200 VW's and are constantly restoring one after another you know how to do things.
The Saw will work, but even though my time isn't cheap, I'd do the 30 minutes worth of work with a grinder before I'd spend roughly $130 dollars.
I don't know what kind of grinding wheel you were using but if you get the thin cutting blades it shouldn't take you long. On a good set of pans it will take about 4 wheels to cut the pans completely off, you're just looking at the seat tracks on ghia, you could do it with one or at most 2. I'll test it out for you this weekend when I cut my pans out and the tracks. If it takes me more than an hour I'll be disappointed.
good luck with project, once again I'm just trying to tell you how I do it, I use a grinder for everything because I can control it a lot more than a Saw.
i know what your saying
i tried everything to get the tar boards off
and they wouldnt budge
i baught a ryobi sawzall from home depot for 60 bucks
i have personally had pretty good luck with this brand
and i also needed it for a few home improvement projects as well
and once i started at the pan with the sawzall it didnt even take five minutes
the blade rode along the inner channel like it was on there as a template
perfect easy
only thing i will do differently on the other side is jack the car up enough
so the saw doesnt bash my hand into the concrete when it jumps out
man that was stupid
perfect easy
man that was stupid
