Ghia gaslid years?
- miller
Ghia gaslid years?
Hey I have a 67 ghia and I was wonderng what years the ghia had a gas lid. Can gaslid tanks be put into non gaslid tank years?
- Ghiaddict
The external fuel filler on the right front fender started with 1968 Ghias. It became remotely operated via the cable pull under the right side dash in 1969.
Yes, a conversion could be done to an earlier Ghia but it's a difficult modification. Personally, I like the vintage feature where you must open the front trunk lid for access to the fuel tank filler. Your '67 KG is a rather unique model year and value would probably suffer if major changes like an external gas filler are done to it.
- Goodwrench
I have a 74 Coupe with the external fuel filler door but I prefer the older style tank where you have to open the trunk to fill the tank. This older method has the added advantage that you get to check your spare and keep it aired up so the windshield washer works. Keep the older style and keep the value of the car high. My .02 worth!
Allen Caron
Warner Robins, GA
74 Karmann Ghia
53 MGTD VW Replica Kit Car
"VWs...They turn an ordinary man into a mechanic"
Warner Robins, GA
74 Karmann Ghia
- dpeters60ghia
- miller
- Goodwrench
Gas Tanks
I have one or two vintage gas tanks with the lid. If interested, e-mail me at gjleonhardt@icnet.net
I have other Ghia parts. My web address is http://www.icnet.net/users/partsbin
