steering wheel shakes tremendously
russ_ghia68
Post by russ_ghia68 »
this problem seems to occur in the morning and when you are driving straight ahead. u hit a small bump and all of the sudden all hell breaks loose on the steering wheel, any ideas on how to fix this problem?
dpeters60ghia
Post by dpeters60ghia »
Start by looking at EVERYTHING in the front end.
Wheel bearings? (my brother's '56 Beetle had loose wheel bearings causing this type of condition)
Ball joints/ King-link Pins
Tie-Rods/ends
Front Beam bolted securely to Chassis?
Tire Balance
It doesn't sound safe...get it checked out before something BAD happens.
- Doug
Max Welton
Post by Max Welton »
Stearing Damper?
Air-Cooled Head
Post by Air-Cooled Head »
Doug said it; Check everything!
I've seen a broken shock tower cause this. (Top rusted out so top of shock was bolted to nothing.)
Canman
Post by Canman »
I'm with Max, steering damper.
Easy to fix, not expensive.
russ_ghia68
alright guys thanxs, does anyone know what would cause this? old age?
its odd that it only does this when its not fully warmed up. pretty odd
Guest
Post by Guest »
Steering damper. Pull it off and push the piston in and out. It should go smooth in both directions, no skips or binds. If it has any binds or skips it's bad. Loose wheel bearings will further aggravate the symptoms. But, check everything.......
Bruce2
Post by Bruce2 »
I agree with the steering dampner diagnosis, but bad shocks will contribute
Post by Marc »
A new steering damper may stop the symptom but that doesn't mean the problem is cured. Remember that early VWs didn't even have dampers - if everything is in tip-top shape they aren't needed. Check that the four bolts which hold the top of the steering box on are all still snug.
johanlu
Post by johanlu »
I have had this problem on an old VW with NO stock steerdamper. Seems to be tires that are biggest part of the problem, even though as previous writers say, it may not have happened if all other things are in perfect shape and You have a newer car with steerdamper.
Problem can be caused by old (hard rubber / bad cord) and unbalanced tires. When using good tires this is less likely to happen!
Note that steering wheel does NOT vibrate or shake other than when you hit a bump (railroad crossing for example) so you won't think it can be the tires... But it can!
