High Speeds
You know, de-chromed, big Porsche rims, Brembos, etc.,... German Look rules!
TKisner
High Speeds
Post by TKisner »
Hello, Euro Look or at least my interpretation of it has particular emphasis on high speeds with handling to boot. I was wondering exactly what is the high speed you guys have ever driven in your volkwsagon as well as what is the highest speed you have ever maintained for a couple minutes. Thanks alot
roachghia70
Post by roachghia70 »
i've held my ghia at over 100 mph several times. and there was one time i got into it with a honda on the freeway where i took the ghia to 6000 rpms in fourth for about 10 miles. he hit his speed limiter and i just kept going. the car felt amazingly stable. but to be honest, the motor really didn't like that.
(hope my dad's not reading this :wink: )
Autocross 58 Bug Build: viewtopic.php?f=19&t=134433
Eurolook71
Post by Eurolook71 »
i buried the needle once in my ol' 71 soup. it had a 100 cam, but a stock carb, 1.25 rockers...1600. I would say for about 3 mins...felt like about a 100mph. this was on the 91 freeway...amazing there was room to go that fast on the 91 for that long! Oh, and yeah, mi motor didnt like it much either, but i was built right cuz it lasted another 2 years! After mucho hard driving when I moved to Idaho 4 a while...but there it was on dirt roads, so no real top speeds. But going 80 on a dirt road's pretty crazy!!! (to the point of a helmet at least, and never passengers!) my first REAL taste of some rally racin'!! GOOD TIMES! :)
PW4056
Post by PW4056 »
1776, 110cam, 44heads, Kadrons, pointer pointing south! :D
EASY RIDER
Post by EASY RIDER »
My 102x71 is done! It will be a month or so before it is in and running and a few more after that before I did this post up and tell ya my story. I will have a story.
Bruce2
Post by Bruce2 »
I held mine wide open for 15 min in Northern Mexico in the Sonoran desert. That works out to about 115mph. Wide low profile tires gives lots of stability. A proper alignment is a must.
Slow 1200
Post by Slow 1200 »
:shock:
Bruce, what did the oil and head temp gauges show at that speed for that long? (if fitted)
Bruce2
Post by Bruce2 »
Damn hot!
Oil got up to 260ºF (125ºC). No head temp guage. But because the rpms were so high, and I use an overdrive bottom pulley, I doubt the heads got too hot.
Part of the reason oil temp goes so high is at high rpm the higher pressure causes the oil to bypass the cooler.
orange72
Post by orange72 »
i hit 85 mph when i am in bad mood...hit 95 mph before...engine is a 1641 with 100 cam
havent hit a hundred, motor feels like 80 is a safe limit, 90 is a stress, plus i have stock brakes with a bad master cylinder and wanna be able to stop
vwpride73
Post by vwpride73 »
I've had mine upto 90 for about 2 miles. I didnt like it and neither did my engine. Stock 1600, with merged header. :roll:
Wally
Post by Wally »
Mine did 188,7 km/h . Thats reading fom a digital speedo measured with the front tire circomference as data put into the speedo computer.
That means its dead accurate. 188,7 = 117,27 mph at 5950 rpm in a 1303 with 3,875 AT trans and a hot type 4 1971cc engine.
Stability was reasonable enough not to back out, but scary still. No spoilers or front air dams.
Greetings,
Walter
T4T: 2,4ltr Type 4 Turbo engine, 10.58 1/4 mi
www.apfelbeck.nl
Paul Illick
Post by Paul Illick »
Do you remember the tire size, Wally?
Roach: Hmmmm....
Theo
Post by Theo »
I got a ticket for 115 mph. I was slowing down. The cop made me open the decklid to look at the motor. He wrote me up 115, I no doubt deserved it. I had it opened up for like 10 miles. The Cop was pissed cause he had trouble catching me. When I opened the decklid for him I was almost certain it was going to flash into a big fire. Oil was leaking everywhere and she was smoking big time.
This was in a Ghia with a Burg 1680.
Many years ago when I was young and stupid. A girl was in the car with me (excuse).
Theo
theo_m24
Post by theo_m24 »
My buddy Manny was arrested for doing 140 something...... This was a good 12-13 years ago...'
Pleaded no contest in court.... Clean record judge went easy on him..... People go to Jail for those kinds of speeds today.....
EASY RIDER
140 in what?
With what engine?
